PLS. HELP problem with LANCER 95 GLXI
Hi I'm from the Philippines, I just bought a used car lancer glxi automatic 95 I just changed it's transmission. now my problem is
after using it for a week. after starting the engine and putting the gear to drive about 400meters of moving, it seems the engine is
choking. and the idle would go to zero. I tried changing the airflow meter, servo spark plugs I was thinking maybe the computer box
but isn't it if it has problems with that the check engine indicator on the panel wouldn't go off??? pls. help I'm really at a lost to what
the problem is. email me at bluhills@mozcom.com. it would really be a big help if I can get some fresh ideas from you guys..
jpdaluz
Jul 7, 2015 05:30 AM
