po300
Old Dec 9, 2006 | 05:33 PM
xslim69's Avatar
Default po300
i have a ramdom missfire on a 97 gst. i have replaced 2 coil packs, plugs, and have msd superconductor wires, i also replaced the maf. im in a nut shell i dont know what could be causing the problen, i replaced all of the ignition system. i been trying to fix this proble for about 6 mounths. now
Old Dec 9, 2006 | 06:07 PM
Manybrews's Avatar
Default RE: po300
have you checked compression? Correct timing? fuel pressure?
there are dozens of things that could cause a misfire. Why not get it professionally diagnosed instead of shotgunning parts at it.
also, aftermarket wires (like the MSD) are trash. Factory wires are definatly a much higher quality.
Old Dec 9, 2006 | 08:49 PM
xslim69's Avatar
Default RE: po300
it is a brand new motor. yes it has the right fuel pressure, ect. o and when u run a msd ignition box (like i am) u need to run their supedcoductor wires. also the stock wires do the same thing.
gordonsen
Aug 24, 2013 09:18 AM
jay_yrbrgh
Feb 4, 2009 09:18 PM
Larimer522
Jan 31, 2009 07:45 PM
