Popping Trunk Switch and Alarm Tripping
Old Nov 15, 2005 | 04:01 PM
TXSpyder's Avatar
Default Popping Trunk Switch and Alarm Tripping
Two questions in one post to save space but how do you get the switch to pop open the trunk working? I have tried inserting the key? When I insert the key into the trunk it does not pop open which sucks when you have a grocery basket and you have to lay it into your car to get your trunk open as it takes two hands?
Other question I have a Code Alarm for a 01 GT Spyder and it occasionally trips out and normally you should put the key in the third spot - I cant remember the abbreviation onthe slot but its either the second or third section of the ignition and hold the arm button on the key pad will I have tried this and all other combinations. I have tried the valet mode switch? Anyone had this alarm or familar with alarms and tricks to resetting them
Kelly
Old Nov 15, 2005 | 05:32 PM
Patrick's Avatar
Administrator
Default RE: Popping Trunk Switch and Alarm Tripping
you dont have remote entry for the trunk?
and i dont understand your second question..i must not have a similar system to you..sorry.
Old Nov 15, 2005 | 09:00 PM
Lil red's Avatar
I have to put the master key in the drivers door and unlock it to get my alarm to shut off...
Old Nov 15, 2005 | 10:57 PM
TheAdvocate's Avatar
I still dont know how to turn mine off other then unhooking the battery
bayspeed
Aug 19, 2010 04:16 PM
fizzwhiz1
May 23, 2010 08:42 PM
elmiserable
Jan 20, 2009 08:18 PM
elmiserable
Jan 20, 2009 08:13 PM
jdragon1974
Aug 1, 2005 12:56 AM
