PULLEY & BELT QUESTION / PROBLEM
Old Jul 14, 2006 | 12:05 AM
micahman's Avatar
Default PULLEY & BELT QUESTION / PROBLEM
ok i have a 1g talon which is just like my eclipse and i have gone through 5 belts in the past 2-3 months. i tighten them properly, but after a while the belt just starts squeeling. i installed a aftermarket volt meter gueage to read the voltage correcty. i run the car so i can adjust the belt so it stops squeeling and the volts read in the right range. it will be fine for about 3-4 weeks then i look under the hood and i see belt dust all over. if i loosen it anymore it will squeel and the alternator wont charge but if i tighten it up anymore it will burn up and break. what do you guys sugest i do?
also i was wondering if a bad waterpump bearing could be the problem why there is so much friction?
all your guys's help is greatly appreciated.
Old Jul 14, 2006 | 01:22 AM
dirtwagon's Avatar
Default RE: PULLEY & BELT QUESTION / PROBLEM
I'm not familiar with your particular application, but it sounds to me like something is out of balance, whether it is a pulley or a bearing I'm not sure. Does everything look true while it's running?
Old Jul 14, 2006 | 02:41 PM
micahman's Avatar
yeah everything looks to be turning fine. all the pulleys look normal with now shaking or vibration.
ultramindbrk
Jan 26, 2025 08:47 PM
waw618
Sep 9, 2009 09:25 PM
wailedflame
Jun 24, 2009 11:12 AM
sr240det
Jun 5, 2008 11:22 AM
LIQUIDSMILE
Jun 16, 2004 04:36 PM
