quick question about flashin ECU
Old Jun 17, 2006 | 01:31 AM
superinflamo's Avatar
Default quick question about flashin ECU
would it benefit it alot? I'm thinking about doing it, but wat are some pro's and con's if there are any?
Will/Can I gain any hp?
daniel
Old Jun 17, 2006 | 10:39 AM
Default RE: quick question about flashin ECU
LOL you wont gain anything. The only time you should need to would be if your car is acting up. All it does is reset the ECU back to factory setting and it has to learn how to idle and all that again.
Old Jun 17, 2006 | 01:49 PM
Ok sebba if you dont know the correct answer then dont answer it becuase you are 100% wrong. A reflash is nothing like resetting an ecu. You can do that with a battery. In a reflash you bring your car to a shop that can tune ECU's. They hook it up to a computer and basically tune it for you. Changing anything that you would like. Note that the changes will remain in there so the only way to change it again is to get it tuned again. I know that a couple things the evo guys do is raise the rev limiter and eliminate fuel cut. But you can basically have them do anything. Im not sure what things you could have done to a 3000gt though. But youd have to contact a good shop for that. But it can be worth it definetly
nyc95gst
Jan 18, 2008 01:25 PM
newEclipse
May 9, 2005 11:59 AM
Cos
Apr 26, 2005 05:50 PM
Dyno_Man
Dec 28, 2004 05:14 PM
Luv Jones
Sep 9, 2004 08:54 PM
