Red stuff leaking out under car all over??
Old Sep 27, 2007 | 04:31 PM
5star's Avatar
Default Red stuff leaking out under car all over??
When i got my car i seen on teh frame and motor that their was some oil on it. but it wasnt really dripping. Well i only put like 300 miles on it since i got it and the oil leak was getting a little worse leaving l;ittle spots under it. Well now last time i drove it i parked it and notaced it was leaking alot. Well i looked under it today and its all over all under the motor is covered and all teh way to teh back to it ran down the frame. But i touched it "and" its oil and red stuff. I think its mostly teh red stuff thats leaking. Whats the red stuff and where is my leaks coming from probably?
Old Sep 27, 2007 | 04:38 PM
estraw's Avatar
Default RE: Red stuff leaking out under car all over??
auto transmission fluid
Old Sep 27, 2007 | 04:41 PM
5star's Avatar
n whys it comin out?
Old Sep 27, 2007 | 04:42 PM
estraw's Avatar
probably a bad gasket somewhere, or your drain plug isnt tight enough
Old Sep 27, 2007 | 05:15 PM
TheAdvocate's Avatar
tranny fluid for sure.. Check by your axles where they go into the tranny..
Old Sep 27, 2007 | 06:52 PM
jpmontero98's Avatar
tranny...check ur gaskets and plugs...
Old Sep 27, 2007 | 08:18 PM
5star's Avatar
could it be from shifting it like a manual? I run it to about 5-6000 b4 shiftin.
Old Sep 27, 2007 | 08:21 PM
estraw's Avatar
yes. dont do that
Old Sep 27, 2007 | 09:24 PM
5star's Avatar
how can it be bad. If its so bad theirs no way they would give you that option on a auto car. And theirs no way its close to the same as shifting a manual with outthe clutch
Old Sep 27, 2007 | 09:29 PM
estraw's Avatar
first off, shiftinga manual without the clutch is bad for your transmission, second off, the cars that come with the sporttronic shifting option are made to be shifted like that. your automatic is made to shift on its own. manually shifting an automatic creates unnessicary heat and wear on the transmission fluid and transmission itself
