Remove RH driveshaft Mitsubishi Spacestar?
This is the 1.3 litre petrol engine.
The outer joint is out of the knockle but inner joint is still stuck in the transmission.
Isn't this a straight pull-out? There are no bolts nor flange at the inner end so i guess it should be possible to pull the axle as a complete unit. I'm aware about the inner joint can be pulled apart if i pull the axle so i grab the inner joint but it still will not move.
Any ideas?
Any ideas?
You just need a pry bar to get in there and pop it out. They can be a pain a lot of the time, but with time just pry in between the transmission and the axle you are removing.
2k1monterosport
May 16, 2011 12:26 AM
