Reving up?
I just bought a 91 eagle talon turbo automatic.... when i start it , it revs upbut when i put it in gear its fine?? any suggestions?
RE: Reving up?
how high does it rev? Also hs it been cold outside, bc on the days its been in the 30's the engine revs high to heat everything up.
RE: Reving up?
rev like how does it go to like 18000rpm then die back down or does it just go up and stay there
RE: Reving up?
I forget... i'll let you all know when i go mess with it again.
RE: Reving up?
Ok well so i lied a bit, I dont have the car but the guy im getting it from says that it revs up but when you put it in drive its fine...
I had a 93 eclipse i just sold and it reved up then died down reved up and died down... just did that till it was warm enough... if you wan to answer that one too since someone asked. |
RE: Reving up?
if it just revs up and stays there sdjust your biss screw back it off a little see if that helps. if it revs up then dies then revs and dies check the iac.
RE: Reving up?
How do I check the IAC?
