Reving up?
Old Feb 9, 2005 | 05:50 PM
DragonRacerX666's Avatar
Default Reving up?
I just bought a 91 eagle talon turbo automatic.... when i start it , it revs upbut when i put it in gear its fine?? any suggestions?
Old Feb 9, 2005 | 09:47 PM
99clipsgst's Avatar
Default RE: Reving up?
how high does it rev? Also hs it been cold outside, bc on the days its been in the 30's the engine revs high to heat everything up.
Old Feb 10, 2005 | 09:49 PM
96awd's Avatar
rev like how does it go to like 18000rpm then die back down or does it just go up and stay there
Old Feb 11, 2005 | 03:44 PM
I forget... i'll let you all know when i go mess with it again.
Old Feb 12, 2005 | 07:56 PM
Ok well so i lied a bit, I dont have the car but the guy im getting it from says that it revs up but when you put it in drive its fine...
I had a 93 eclipse i just sold and it reved up then died down reved up and died down... just did that till it was warm enough... if you wan to answer that one too since someone asked.
Old Feb 15, 2005 | 12:06 AM
96awd's Avatar
if it just revs up and stays there sdjust your biss screw back it off a little see if that helps. if it revs up then dies then revs and dies check the iac.
Old Feb 15, 2005 | 12:34 AM
How do I check the IAC?
joerglamb
Jan 13, 2011 12:39 PM
Shadow
Feb 23, 2008 01:52 AM
lwbero
Nov 23, 2007 08:28 PM
2nd g eclipse gst
Jul 17, 2007 12:42 PM
bdunn
Dec 1, 2004 03:38 PM
