RPM
Old Oct 3, 2006 | 10:23 PM
mr.shug1135's Avatar
Default RPM
While driving at a contant speed rpm's fluctuate repeatly. What could be the cause of my problem.
1990 eclipse gs DOHC 2.0 16 valve.
Old Nov 28, 2006 | 09:00 AM
Default RE: RPM
RPM luctuates repeatly after a min or two while driving at a contant speed.
Old Nov 28, 2006 | 09:22 AM
Default RE: RPM
they go from where to where
Old Nov 28, 2006 | 11:18 AM
Default RE: RPM
does it also do it at idle
Old Nov 28, 2006 | 11:58 AM
Joglo's Avatar
Default RE: RPM
I'm just loving this forum, "Fluctuate repeatly luctuates at contant speed" and he gets replies?
Where am I going wrong with my humble query?[&o]
Does anybody here know anything about electronic systems, or does everyone here simply enjoy answering questions with other questions?
I'm a mechanic with 40 years of experience on VWs, from DIY to owning my own workshop, have no knowledge of electronics whatsoever. I can advise on many ordinary mechanical problems, but just now I need a little help with a problem myself.
Old Nov 28, 2006 | 12:21 PM
Default RE: RPM
well the reason i was asking questions is because there are so many things that can cause rpm fluctuation that more info is needed to figure it out
Old Nov 29, 2006 | 08:04 AM
Joglo's Avatar
Default RE: RPM
Sounds to me like a problem with the rev counter.
Mr shug talks about rev fluctuation while 'driving at a constant speed,' which suggests to me that the speed isn't varying, only the revs on the counter? If the revs were fluctuating, the speed wouldn't be constant!
That wouldn't be much fun if the engine was controlling the driver!!!
Spooky.
Old Nov 29, 2006 | 09:50 AM
Default RE: RPM
well fluctuating rpms can come from a bad IAC or TPS and also a crack in the intake manifold. Could be a bad manifold gasket. And i know theres more i just cant think of them right now
Old Nov 29, 2006 | 12:31 PM
Joglo's Avatar
Default RE: RPM
But if revs fluctuate at constant speed, the speed can't be constant????
Old Dec 4, 2006 | 11:54 PM
Default RE: RPM
I'm sorry the speed isn't constant when the rev fluctuate. The speed also fluctuate along with the rev and it's annoying. I've just repaired a crack on the muffer. I have to check an see if i have a bad manifold gasket. Thanks for the info.
luisantoiof
Apr 17, 2004 11:51 PM
eclipse2gnt03
Jan 18, 2004 04:00 PM
eclipse2gnt03
Nov 20, 2003 06:24 AM
eclipse2gnt03
Aug 1, 2003 02:33 AM
eclipse2gnt03
Aug 1, 2003 01:29 AM
