Say It Ain't So!
Well I am really hoping for any help on this one guys....
I have a 2001 Diamante, 175k miles. Running VERY well, until yesterday. Driving home on the highway, then all of a sudden, it was like i was in neutral. The engine is running, but idling, i pull over and stop. I move the shifter into any gear, R, N, 1, 2, D - nothing. The engine is running, but they all feel like neutral, and the engine just revs when i hit the gas. The check engine light also came on, I havent pulled the code yet. And right when it happened, the gear indicator on the dash was flashing between neutral and whatever position I moved the shifter to. I tried turning the car off and on, and the engine stops and starts, but no dice with the tranny. One other thing to note is that I had the tranny flushed, AT THE DEALER about two months ago. The tranny has run and felt great from day 1 right up until this happened. No slippage, no anything. Before I goto the dealer, I really want to know what happened (or at least have some idea). Was the fluid changed related? Can I read the check engine code with a regular Code reader? or is a tranny code special?! Thanks for the help People. I am really bumming right now, as you can imagine! I hope I get to talk to you all soon, Matt |
RE: Say It Ain't So!
I just checked the fluid... there is fluid, but it is Brown (not red/pink) and smells burnt.
ugh - it is not looking good is it? |
Sounds like you had a pump failure if you have no foreward or reverse gears.
Thanks for the response.
How can I verify the pump is bad? What can I do/look at? |
