Sh*t. No spark...
Old Aug 20, 2013 | 01:26 AM
Akzle's Avatar
Default Sh*t. No spark...
1990 magna, 2.6.
Was going this morning. Think i shorted/destroyed something with immobiliser.
Disconnected everything new.
Coil tests good. And voltage at coil.
Rotor, cap look ok.
Plugs getting wet so fuel in cyls.
When i try cranking 'brake' (rear, not h/brake) light comes on dash. Nevr noticed before.
Igniter (part tim015) SEEMs to be my headache. Tried testing by an old method i knew (hooking to 12v test light, then putting voltage across terminals from dizzy) >fails.
Is there a better test? Am i doing it wrong?
Anything else?
Old Aug 20, 2013 | 02:11 AM
What did you do to it?
I would just call a mobile auto electrician.
Old Aug 20, 2013 | 02:35 AM
Akzle's Avatar
tried hooking in immob.
Immob tests ok (on when switchd, off when active)
dont think i left key 'on' for any lemgth of time. And thatd likely burn the coil anyway.
Believe me, im scratching my head here.
Auto sparky unlikely to carry parts, cant measure more than i have, and i live miles out of town...and short on cash.
Old Aug 20, 2013 | 03:23 AM
They charge about $50 for a callout 'round these parts. That's about as good as you're gonna get.
So the car isn't getting spark. Check the resistance value on your ignition control module.
Old Aug 20, 2013 | 10:36 AM
Akzle's Avatar
that could help... If i could find its specs!
Old Aug 21, 2013 | 09:41 PM
Akzle's Avatar
Default well, f*ck that.
so.... it might not have been the igniter after all (150$ later...)
the ignitor is mounted on top of the dizzy, it HAD a metal cover on it. when the cover is on= no spark.
without the cover, but with the screws in place grounding the unit = spark.
i'm not going to pull it apart again and replace the old unit to test my theory, but finding this out late in the day (after spending MONEY), p*sses me off.
so, it seems my immobiliser wiring was not to blame, now that i've f*cking pulled it all out again
oh well. car runs. happy bob.
new plugs, rotor, cap, and an air filter on the way.
can you believe K&N want 240$??
then i have a long, long list of things to spend money on (bring on the lottery)
strut brace and engine mounts are right up there, followed by shock upgrades. i quite like the 4 point link suspension on the rear, but being a FWD it still handles like a ****ing boat.
ooo, and getting a mechanic out would have cost me 90$ before they'd lifted a spanner...
Old Aug 24, 2013 | 12:48 PM
shadowfiree's Avatar
Default so what was it
what was the problem.... iam like u new ball joints / rear something" arms tune up/ fuel filter/pvc valve/ and now just dont know if i need fuel pump or injectors/ or whatever your problem was... 1992 montero 4wd 3.0L mitsubishi. e-mail or post reply really would like to know thzzzz
Old Aug 25, 2013 | 02:11 AM
Akzle's Avatar
despite your incredibly poor attempt at english, try and wrap your head around this:
vcleynes
Nov 25, 2014 12:59 AM
#1 Stunna
Jun 7, 2007 05:59 PM
lelliott
Feb 25, 2004 11:29 AM
dozracing
Feb 16, 2004 04:41 AM
jesse
Dec 21, 2003 03:43 PM
