shaking
Old Mar 4, 2006 | 08:06 PM
19eclipse91's Avatar
Default shaking
my 91' eclipse is shaking, mainly when its reving lower, it shakes really bad, and i barely get any response from the gas pedal, then when it gets up around 3000-3500 rpms it stops until i have to shift again, then it shakes again.
Old Mar 5, 2006 | 06:51 PM
NESpeed's Avatar
Default RE: shaking
Could be a missfire........Check you plugs and wires, replace them and let me know what happens.
Old Mar 5, 2006 | 07:34 PM
Default RE: shaking
could be just a suspension problem, is it an AWD. I had that problem with my talon. Try shifting the car at higher rpms, like around 4500 and see if it shakes after the shift.
Old Mar 6, 2006 | 05:39 PM
Default RE: shaking
i dont think its my suspension, its more like the engine shaking, so i'm going to take a look at my spark plugs and replace them if i have to, hopefully that will fix the problem
Old Mar 9, 2006 | 09:11 PM
Default RE: shaking
okay well i replaced the spark plugs, and it still shakes, it didn't fix anything, now it barely starts, and when it tries to warm up it will go up to 2000 rpms then drop and go back up again and drop again etc...
Old Mar 9, 2006 | 09:32 PM
Default RE: shaking
ORIGINAL: 19eclipse91
that sounds like a boost leak or a vented BOV
Old Mar 9, 2006 | 10:10 PM
TheAdvocate's Avatar
Default RE: shaking
Sounds like a tune up is needed
Old Mar 9, 2006 | 10:13 PM
Default RE: shaking
ORIGINAL: TheAdvocate
with a bouncing idle is sounds more like boost\VAC leak somewhere
Old Mar 10, 2006 | 11:03 PM
Default RE: shaking
i dont have a turbo
Old Mar 11, 2006 | 02:08 AM
Default RE: shaking
well you still can have a VAC leak and encounter the same symptoms.
