Speedometer/Clock don't work and
I can not get any codes. Anyone knows what can be worng. Thanks
RE: Speedometer/Clock don't work and
Could be faulty wireing in the gauge but i think it might be the speedometer sensor on the gearbox has died. [sm=smiley11.gif]
I replaced the sensor no joy. Going on to replace the wiring harness and board behind the speedo. Any other suggestions.
Replaced speed sensor and internal wiring harness. No joy. Still the clock, interior light, and speedometer don't work. Anyone think it may be the circuit board behind the cluster.
check fuses?
I checked all the fuses too.....
Hi;
If your car is automatic and your speedometer sensor is broken, you should understand this, cause the car doesnt change the gears, it stays at maximum gear. I suspect the cable which is connected to stereo. When my stereo was broken it wasn't show the average speed, L/100 and maximum KM to gas station informations. By the way. My car doesnt show current gas spend information. On the handbook it says that it shows current gas spend, average gas spend, average speed and kilometers to gas station. Is there any problem or the hand book is wrong? Mehmet |
My car is manual and which cable of the radio is that. I installed an aftermarket radio.
Tks, |
I got my speedometer sensor broken one time and it worked just like I wrote in previous message. Since your car is manual you'll not feel this difference. The cable is behind the stereo, there are 3 pieces of cables there. One for the antenna, one socket for other radio control and one for the information screen(small group) (I dont remember which color) . Maybe I'm wrong but you can check that cable group, cause all the information screen data comes to stereo and then goes to info screen. Since you have an aftermarket radio you should not be able to see those values on the info screen already. (May be just one value)
Mehmet |
