Speedometer/Clock don't work and
Old Jun 27, 2004 | 04:43 PM
yoboricua's Avatar
Default Speedometer/Clock don't work and
I can not get any codes. Anyone knows what can be worng. Thanks
Old Jun 28, 2004 | 05:44 AM
Seth's Avatar
Default RE: Speedometer/Clock don't work and
Could be faulty wireing in the gauge but i think it might be the speedometer sensor on the gearbox has died. [sm=smiley11.gif]
Old Aug 4, 2004 | 12:13 PM
yoboricua's Avatar
I replaced the sensor no joy. Going on to replace the wiring harness and board behind the speedo. Any other suggestions.
Old Aug 14, 2004 | 02:07 PM
yoboricua's Avatar
Replaced speed sensor and internal wiring harness. No joy. Still the clock, interior light, and speedometer don't work. Anyone think it may be the circuit board behind the cluster.
Old Aug 14, 2004 | 09:05 PM
unplugged_nate's Avatar
check fuses?
Old Aug 14, 2004 | 10:53 PM
yoboricua's Avatar
I checked all the fuses too.....
Old Aug 16, 2004 | 12:15 PM
mturker's Avatar
Hi;
If your car is automatic and your speedometer sensor is broken, you should understand this, cause the car doesnt change the gears, it stays at maximum gear.
I suspect the cable which is connected to stereo. When my stereo was broken it wasn't show the average speed, L/100 and maximum KM to gas station informations.
By the way. My car doesnt show current gas spend information. On the handbook it says that it shows current gas spend, average gas spend, average speed and kilometers to gas station. Is there any problem or the hand book is wrong?
Mehmet
Old Aug 16, 2004 | 10:06 PM
yoboricua's Avatar
My car is manual and which cable of the radio is that. I installed an aftermarket radio.
Tks,
Old Aug 17, 2004 | 05:15 AM
mturker's Avatar
I got my speedometer sensor broken one time and it worked just like I wrote in previous message. Since your car is manual you'll not feel this difference. The cable is behind the stereo, there are 3 pieces of cables there. One for the antenna, one socket for other radio control and one for the information screen(small group) (I dont remember which color) . Maybe I'm wrong but you can check that cable group, cause all the information screen data comes to stereo and then goes to info screen. Since you have an aftermarket radio you should not be able to see those values on the info screen already. (May be just one value)
Mehmet
evrchanging-ecl
Jan 16, 2014 01:36 AM
Red Dragon
Sep 22, 2011 04:29 AM
justyn01
13
Jul 10, 2011 05:34 PM
la80vette
Apr 4, 2008 12:06 PM
yoboricua
Jun 27, 2004 04:45 PM
