stock injectors
what is the most boost the stock injectors can handel with an safc. I want to boost them at around 18psi.
RE: stock injectors
Well it all depends on what year DSM you have. If its a 1G you can get away with 18psi accompanied with a fuel pump. If its a 2G then the t25 wont even give you efficient boost at 18psi, but you would also need a fuel pump.
RE: stock injectors
well i have a 50 trim turbo with 255 fuel pump and an safc. so with that can the stock 44cc handel the 18psi
RE: stock injectors
ORIGINAL: jdm2ner well i have a 50 trim turbo with 255 fuel pump and an safc. so with that can the stock 44cc handel the 18psi |
RE: stock injectors
450cc injectors is what i was trying to say. So that is a BIG NO on 18psi on stock injectors
RE: stock injectors
would the 550cc injectors from an evo work on my car? which is a 2g eclipse!
RE: stock injectors
I think that they would. I am not totally sure on that. But once again we are trying to make sure that you know on the stock turbo running 18psi it will not run very efficcient.
RE: stock injectors
I know that the stock turbo would not work for 18psi. I have a 50 trim turbo from slowboy racing.
RE: stock injectors
ORIGINAL: jdm2ner I know that the stock turbo would not work for 18psi. I have a 50 trim turbo from slowboy racing. |
RE: stock injectors
Yess EVO 550s will fit and I am running 21PSI on stock 550s and stock pump with the stock twin scroll 16G.
What kind of turbo is it do you know anymore other than the 50 trim? got pics of it on the car or out of the car? |
