stock injectors
Old Mar 12, 2006 | 09:33 AM
jdm2ner's Avatar
Default stock injectors
what is the most boost the stock injectors can handel with an safc. I want to boost them at around 18psi.
Old Mar 12, 2006 | 01:10 PM
NESpeed's Avatar
Default RE: stock injectors
Well it all depends on what year DSM you have. If its a 1G you can get away with 18psi accompanied with a fuel pump. If its a 2G then the t25 wont even give you efficient boost at 18psi, but you would also need a fuel pump.
Old Mar 19, 2006 | 01:47 PM
jdm2ner's Avatar
well i have a 50 trim turbo with 255 fuel pump and an safc. so with that can the stock 44cc handel the 18psi
Old Mar 19, 2006 | 03:45 PM
ORIGINAL: jdm2ner
arnt they 450cc or maybe 440 which my guess is what you ment. I wouldnt run that high of boost on stock injectors. I dont think that youll have much to tune with an SAFC youve gotta be pretty lean at 18 PSI
Old Mar 19, 2006 | 11:14 PM
jdm2ner's Avatar
450cc injectors is what i was trying to say. So that is a BIG NO on 18psi on stock injectors
Old Mar 19, 2006 | 11:21 PM
jdm2ner's Avatar
would the 550cc injectors from an evo work on my car? which is a 2g eclipse!
Old Mar 20, 2006 | 09:37 AM
I think that they would. I am not totally sure on that. But once again we are trying to make sure that you know on the stock turbo running 18psi it will not run very efficcient.
Old Mar 20, 2006 | 04:28 PM
jdm2ner's Avatar
I know that the stock turbo would not work for 18psi. I have a 50 trim turbo from slowboy racing.
Old Mar 20, 2006 | 05:00 PM
ORIGINAL: jdm2ner
oh ok i missed that
Old Mar 20, 2006 | 06:49 PM
Yess EVO 550s will fit and I am running 21PSI on stock 550s and stock pump with the stock twin scroll 16G.
What kind of turbo is it do you know anymore other than the 50 trim? got pics of it on the car or out of the car?
