Timing Belt
anybody got any tips for changin a timing belt on a '00 eclipse RS???[&:]
RE: Timing Belt
estraw,
I don't know which engine you have, but here are some general tips. - I'd encourage you to replace the tensioner with the belt; especially if it wasn't replaced when the belt was last replaced. - As it's a lot of trouble to get to the belt, I always replace the water pump while I'm there. - After getting to the belt, BEFORE removing it, it would be a good exercise to line up the timing marks on the cam and crank gears with their counterparts on the block and head. If your particular engine has a shaft for the oil pump, it would also be a good idea to note where it lines up before removing the belt. Good luck, Jeff |
| All times are GMT -5. The time now is 04:10 AM. |
