trouble code 64
Old Mar 10, 2006 | 10:56 PM
magnet's Avatar
Default trouble code 64
IM getting the trouble code 64 (catalytic converter efficiency below required level). I checked this using the key on-key off meathod of retrieving the codes. I also got a code 12 which is the IAC valve I believe. Any ideas on where IO should start here? I hate to just start replacing things and hoping to get it right. Thanks for any help!
Old Mar 11, 2006 | 12:18 PM
NESpeed's Avatar
Default RE: trouble code 64
How many miles on your car?
Old Mar 12, 2006 | 12:31 AM
magnet's Avatar
170,000, and I did change the plugs and wires before that and that didnt seem to be any cause that I know of because this code was thrown several days after that.
Old Mar 12, 2006 | 11:50 PM
magnet's Avatar
anyone?
Old Mar 13, 2006 | 12:35 AM
NESpeed's Avatar
You could have a bad cat with the car having that many miles. Did you rest your ECU to see if it you get the code again?
Old Mar 13, 2006 | 01:01 AM
magnet's Avatar
no but I can try it. do I need to unhook the battery for awhile or take it to have the codes cleared?
Old Mar 13, 2006 | 11:46 AM
no you should only have to unhook it for a minute or two.
Old Mar 13, 2006 | 02:41 PM
3g eclipse's Avatar
Do you have a high flow cat. or cold air intake on your car?
Old Mar 13, 2006 | 06:35 PM
magnet's Avatar
theres a cold air intake (I think) that came with the car but its not installed. And no I dont have the hi-flo cat, I think the original is the one that on it.
Old Mar 14, 2006 | 02:31 AM
did you try and reset the computer. If it didn't work then like nespeed said, its probably a bad cat.
