Trouble shooting my 95 eclipse gst
Old Nov 18, 2007 | 07:12 PM
doubleroost's Avatar
Default Trouble shooting my 95 eclipse gst
Just to start I'm new to this car. I usually work on trucks. I just bought a 95 eclipse gst 166,000 miles, auto trans. I have 3 issues that need some advise on.
1. The front end makes a thumping noise randomly after a bump. I pulled the front wheels and check out everything and the only thing i noticed is that the bushings for the sway bar and worn, and theres a tiny bit of play in the rack.. Maybe the struts are bad though?
2. The check engine light is on and the code is P0505 Idle air control system, the car idles high (1100rpm) and fluxuates. I did some research on google and people say to start with changing the idle speed controller (ISC). Is that a good place to start?
3. When you push the pedal (moving) to the floor it feels like the motor is breaking up and jerking. It idles ok and i checked the plugs and the turbo and they seem to be in good shape. I read in the repair manual and it says something about the fuel filter being clogged.
Any advise to get me started would be greatly appreciated. Thanks.
Old Nov 18, 2007 | 07:43 PM
dsm1990gsx's Avatar
Default RE: Trouble shooting my 95 eclipse gst
1.Try replacing your sway bar bushings and check your links if they have any play.
2.Replace your isc motor
3.Is it misfiring? Try a tune up andreplace your filters.
Old Nov 23, 2007 | 03:53 PM
smokinu6's Avatar
check your front end good upper ball joints and lower control bushings .check the throtle body for carbon build up ohm out your coolant temp sensor it will through a faulity or miss leading code. do you have a dis system?
Old Nov 24, 2007 | 01:27 PM
Exactly what dsm1990gsx said, only replace the plugs with NGK classics and some Mitsubishi factory spark plug wires.
Old Nov 25, 2007 | 05:55 PM
Ok so I swapped out the fuel filter, changed the plugs and wires... The old plugs were ok looking but the gap was way off. Anyway it it drives alot better now. No breaking up and the tranny is shifting smoother. I still have to work on the front end. Also I turned the idle down on the throttle body and since a couple days ago the check engine light hasn't come back on. So I guess i'll wait and see what happens before i find a new iac.
Old Nov 25, 2007 | 06:53 PM
dsm1990gsx's Avatar
Make sure you check the timing w/ a timing light and make sure all that is fine too.
beetlenut
Jan 22, 2017 06:11 AM
_it___is_i
Apr 2, 2015 07:58 AM
imtgw1a
Mar 10, 2009 05:13 AM
2slow
Aug 29, 2007 08:45 AM
krustykenevil
Nov 10, 2006 02:23 PM
