Vacuum line for boost gauge... good spot?
Old Mar 29, 2005 | 10:17 PM
mitsunoobie's Avatar
Default Vacuum line for boost gauge... good spot?
Hey, this is where i T'd my vacuum line for my boost gauge. Is this a good spot? Not sure if it's coincidence or not, but I'm getting a check engine light, and it seems like it started right after the installation. Where would you guys recommend I put it?... if this is a bad spot.
Thanks guys
Old Mar 29, 2005 | 11:24 PM
DSMTalonAWD51's Avatar
Default RE: Vacuum line for boost gauge... good spot?
you want the guage coming right from the intake manifold so yea thats a fine spot. it shouldnt trigger your check engine light though so make sure there are no leaks and if you cant find a problem reset your ecu to see if the light comes back on
Old Mar 30, 2005 | 02:23 AM
dsm king's Avatar
I would recommend using small clamps instead of zip ties though
Old Mar 30, 2005 | 09:48 AM
yeah i was going to do that but i went to auto zone and advanced and jegs all of the shops were out even meijer (sp?) so i had to make due :/
Old Mar 30, 2005 | 05:54 PM
zip ties are fine thats what i used you can get those guys pretty tight
Old Mar 31, 2005 | 10:46 AM
i used plyers and a screw driver to get them as tight as possible without crushing anything. and i read 10 psi stock is that the correct amount of boost i am suppose to be running? i am trying to find out everyting before i mod so i can tell if everything is currently ok before i do.
Old Mar 31, 2005 | 06:31 PM
10-12 psi sounds about right
Old Apr 1, 2005 | 10:22 AM
cool well time to start spending money lol
Simss
Nov 8, 2006 01:16 PM
agallardo
Aug 29, 2006 02:07 AM
T76 turbo
Apr 16, 2004 04:53 PM
T76 turbo
Apr 15, 2004 01:02 AM
