Vertical lift door questions sort of
All right I have decided to give the enging a rest for a while and tackel the vertical lift door lifts on my car.
So, much of this is prety self explanatory to me, I have the bolt on on the car and I think I've more or less gotten it linned up. Here is where I ran into a small problem. My fender is not fitting right. Now I read somewhere that you need to roll the fender. Where the fender meets the door there is a lip where it is bolted to the frame,Is this the area that will need to be cut and folded ? I mean it looks like it should be folded but I would like to be sure before I start cutting things up you know?
Because of the fact that so many of you have read this and yet no one has seen fit to respond I'm going to assume that; (a) I'm right. (b) no one knows. (c) no one cares. Regardless I think I'm goint to go on with what I was going to do in the first place. Thanks guys.
Tacky, maybe. But hey I'm a 33 years old man putting a 97 eclipse together. I think tackey would most likely be the nicest thing said about me around my house. I'm just putting together a car he way I want it you know? Anyway I guess if I figure it all out I'll see if the guy in charge wants me to post an arrtickle on it. But as many of you have said it might be a mote point.
thextranscended
Feb 16, 2005 10:04 PM
