Water Leaking on Carpet- Passenger Side
Old May 28, 2007 | 06:01 PM
Galvinized80's Avatar
Default Water Leaking on Carpet- Passenger Side
I have an '02 Lancer ES, and water leaks onto the carpet on the passenger side. I have done some research and I think that it is something to do with a clogged drain hose that comes out the firewall. I think I have even found the hose, but I do not know how to clean it. Can someone help?
Old Jun 1, 2007 | 07:24 PM
sk8dudety's Avatar
Default RE: Water Leaking on Carpet- Passenger Side
try blowing air into with an air line, thats how i cleaned my hose in my eclipse... if that doesnt work stick some sort of coat hanger or wire through it to push out to blockage
Old Jun 3, 2007 | 11:29 PM
razvan76's Avatar
Man that almost sound like bad heater core. I just had to replace that. HAd to take th eentire dash apart. Dealer wanted $700 for this, I just bought the core for 80 and replace it myself.
Does it smell like antifreze? Does it fog up th ewindow or just water?
Old Jun 4, 2007 | 11:58 PM
It doesn't smelll like anything, just water.
I'm no mechanic, but I have to fix it because I don't have the 1200 to 1500 dollars the dealer said it would take to fix. Is the drain that I am looking for a black rubber 'L' piece that is a pain in the rear to get at? If so, how do you get air into it? If not, where should I look.
Old Jul 6, 2010 | 11:27 AM
02Lancer1971's Avatar
I have a 02 lancer that I bought about 8 months ago, the other day I was driving and turned a corner heard a sound that sounded like a can spraying and then water began pouring in my floorboard on the passenger side. Does anyone know what this is and how to fix it? I drove approx. 1/4 mile before pulling over and had about 2 inches of water in the floorboard. I wet vacd it out and haven't ran the air since, it is HOT and I need help!!!
Jun 8, 2013 05:57 PM
SpyderDave
Dec 6, 2011 09:02 AM
Kptaylor
Jul 28, 2011 02:17 AM
bcolins
15
Mar 31, 2010 11:55 AM
bishigt_18
Nov 1, 2008 07:24 PM
