were is he BOV located on a 1997 gst spyder
Old Nov 28, 2005 | 06:08 PM
anko_kun's Avatar
Default RE: were is he BOV located on a 1997 gst spyder
i think eveery thing is legal in texas
Old Nov 28, 2005 | 06:52 PM
ORIGINAL: anko_kun
dont went to the atmosphere, its stupid and your car will run like a bucket. the special lind is a BOV with re-circ kit. the Greddy type s is popular as is the 1G crushed, the 1G is cheap and a good modd for the money.
If you vent it to the atmosohere your car is calculating air that teh BOV is letting go the ECU assumes the air is still there and adds fuel so the car goes super rich every time the BOV opens and will stumble if you allow the rpms to drop to idle after accell under boost, it will cause longer turbo lag between shifts, and it can stall out I have had that happen to me once when VTA for a few miles cause I nedded to weld in a dump off into my intake. VTA is only going to run right if you attempt to tune it out even then it wont be perfect or if you buy a stand alone or GM mas air
Old Nov 28, 2005 | 07:24 PM
TheAdvocate's Avatar
That sound is sweet tho I have a stock 2g blow off valve, but i think it was crushed b/c it is extremely loud... But it doesnt have the pull that it should when the turbo spools up...
Old Nov 28, 2005 | 10:30 PM
anko_kun's Avatar
how much is a g1 BOV and is there a advantage to the type-s
Old Nov 29, 2005 | 01:20 AM
ORIGINAL: anko_kun
I think the 1G and type S are similar in Max PSI. not sure of the Max on the 1G but the Typea S is around 25 PSI from what I have read, it is arguable though.
The 1G will cost prob. around $100 or so the type S new from Greddy im sure is $200 something atleast.
Old Nov 29, 2005 | 01:22 AM
ORIGINAL: TheAdvocate
sounds like VTA. I dont know for sure but I didnt think crushing made it louder, maybe a dif. sound. A VTA BOV will be extremely loud though
Old Nov 29, 2005 | 12:58 PM
Blue03Evo's Avatar
ORIGINAL: anko_kun
yeah that is just about right. I get right beside cops all the time and blow off and they dont say a damn thing.
Old Nov 29, 2005 | 01:03 PM
Blue03Evo's Avatar
the 1G BOV's hold about 20pounds. i have also herd if you have the 95 computer or MAF that if you vent than you want have a problem with the idle. my buddy has a 95 GST with a 1G BOV that he vents and his has no problems out of it.
For the money i would go with the 1G BOV, but if you have the money to spend than go with the Greddy type s.
Old Nov 29, 2005 | 05:07 PM
DSMTalonAWD51's Avatar
ORIGINAL: EMonz57
ORIGINAL: anko_kun
Wow high prices. People on my local sd forum sell used type s's for $75 average. You can find a 1g bov for around $20. As for crushing, it does not affect sound. The crushing enables it to hold more boost. A stock 1g bov should be good for 16sih psi, but since its metal, you can crush it and it will hold up to 20-22 psi
Old Nov 29, 2005 | 05:20 PM
ORIGINAL: DSMTalonAWD51
ORIGINAL: EMonz57
ORIGINAL: anko_kun
ya on a forum a type s is cheap but on Greddys site it isnt. and I never knew what a 1G BOV was sold for so I trew a # out there lol since the EVO guys do the same with the MR JDM DV and that is around $130 I just guessed on the 1G
