white smoke???
Old Jul 25, 2008 | 04:23 PM
96420ars's Avatar
Default white smoke???
Ok, I wasnt sure if I remembered correctly or not but isnt it when theres white smoke coming out of your exhaust pipe then the head gasket is going bad? i just cant remember for sure and wanted to know, cause well clearly theres white smoke coming out of mypipe [&o]
Old Jul 29, 2008 | 08:14 PM
Ikaros97's Avatar
Default RE: white smoke???
Check for oil in water and / orwater in oil, water level etc. Do you have a misfire, overheating?. If all is ok here then I suspect it could be your Turbo.
Ta
Old Jul 30, 2008 | 07:08 AM
^^judging by his name id say he doesnt have a turbo
Do a compression check. More than likely its the head gasket with that car. But it may have to do with running rich for whatever reason. But id just start with the compression
Old Aug 21, 2008 | 05:38 PM
96420ars's Avatar
Yea definitely no turbo on the car, which is why its extremely slow[:@]
haha.
But uh well at one point i was driving without the header o2 cause it snapped
on me a while back and i knew thats why it was smoking then but ive got on a
new o2 now and it still smokes. So but yea, i had my suspicions on the head gasket
or possibly the valve seals leaking some oil into the motor and its burning off and
letting out the smoke, not sure. I'm gonna have my mechanic that i go to check it
out for me and figure it out cause idk how to do a comression check, considering
im basically a noob still at working on cars haha. I'm about to start tech
college soon tho for automechanics sooo, ill know everything soon enough haha.
Thanks for the help and info guys, although now i want a turbo but cant have
one just yet [:@] haha
Old Aug 22, 2008 | 09:54 PM
blue450yo's Avatar
I built and rebuilt many engines.
White smoke is water in the oil (gasket/crack)or running lean.
Blue smoke is oil.
Black smoke is rich.
If it smokes only on start up and for a few minutes the oil is getting past the valves. If it smokes the whole time you ride specialy at high rpm and on decel its your rings.
Old Sep 6, 2008 | 02:04 PM
96420ars's Avatar
Ahhhh, thanks for the info blue. Then yea its a gasket or crack or lean then cause its white smoke and its only when its idling, while on the throttle though it doesnt smoke ever so yea, idk, im getting it fixed whenever i talk to the freakin mechanic at my shop so ill know what to tell him to replace then now, thanks again for all help guys.
car doctor
Aug 9, 2015 04:52 PM
BrunoBoy650
May 31, 2006 07:39 PM
t4_gsx
Mar 3, 2006 07:29 AM
kingman4309
Feb 22, 2005 03:03 AM
EclipseSlimRS
May 16, 2004 07:10 PM
