Exterior Talk about your rims, body kits, and other exterior mods here.
rims and tires
Old Jul 21, 2007 | 06:09 PM
Shaun VanCity GST's Avatar
Default rims and tires
what size rims and tires should I put on my 97 Spyder GST? I was thinking either 18's or 19's, but I don't know what size rubber... and unfortunately I don't know too much about tires and rubber.... I have the stock rims now. 205/55/16.... the things I'm not sure about is the offset and things like that. I know what the 205/55/16 means... any help out there would be appreciated. sorry for my ignorance....Shaun
Old Aug 22, 2007 | 12:39 AM
RedGalant2k1's Avatar
Default RE: rims and tires
Tire sizes you can use are as follows:
215/40-18
225/40-18 (recommended)
235/40-18 (requires minor mods to fit)
215/35-19
225/35-19 (recommended)
235/35-19 (requires minor mods to fit)
Make sure that you get a wheel with a offset as close to stock as possible (i.e. +40-46mm). Also I'd recommend nothing wider than a 7.5" wide wheel. I know there are 2g Eclipses with 8" and 8.5" wheels, but those require mods you may not want to make to fit properly without rubbing, or may not be the look you want.
Old Aug 22, 2007 | 03:38 AM
silvercoupe97's Avatar
The DSM VFAQ has a lot of good, tried and true info.
http://www.vfaq.com/mods/macross/2Gfitment.html
Use this calculator for tire sizing also...
http://www.1010tires.com/TireSizeCal...?action=submit
Just plug in your current size and then the size you want and this will calculate how much faster or slower your wheels will spin with whatever configuration you get or want.
Stock offset for your 2G is +46mm. The lower that number goes the farther out the wheel goes. The larger the offset number goes, the farther in it goes. Follow?
I don't agree with a larger than 17x7" wheel because of performance issues, unless you get light rims, but that's up to you.
Old Aug 22, 2007 | 11:58 AM
Motegi makes some lightweight 18s and 19s.
Old Oct 9, 2007 | 07:02 PM
gt's Avatar
gt
Hello.
I have a question .Silvercupe97 do you have any photos of your Eclipse online,because id like to buy 17x8 et 35 for my Eclipse GS and i'm very sceptic about it. I would be verygratefulforfor some pics and coment about this size and fitment ofthisrims.
Thank you very much for your help and time . Jurij
Old Oct 9, 2007 | 08:09 PM
ba3kgt's Avatar
i dont think he has an eclipse and u might wanna try pm'in him for pics or look at his profile
Old Oct 10, 2007 | 02:42 PM
gt's Avatar
gt
i assumed that he own an Eclipse since he now so much about the rims for Eclipse .But thanks anyway
Jurij
enzo_hashmat2006
Aug 7, 2006 06:45 PM
silvereclipse06
Sep 6, 2005 08:25 PM
dkostis
Jul 2, 2005 04:38 PM
Kabuki24
Jul 1, 2005 09:17 AM
Fibercation.com
Feb 18, 2005 12:14 AM
