2001 Montero Sport 3.5 127,000 mi.
8 codes after the rebuild ????
Hello again, I just got done with the Top and Front rebuild and runs like a champ with a bit of a crappy Idol for some reason. I am getting 8 codes now as follows. 1--P0174-- bank 2 system to lean 2--P0154--oxy circuit no activity detected bank 2 sensor 1 3--P0401--exhaust gas recirculation flow insufficient flow detected 4--Po111-- intake air temperature sensor 1 circuit range / Performance 5--Po107--Manifold absolute pressure circuit or barometric pressure low input 6--P0174--bank 2 system to lean 7--Po154--oxy circuit no activity detected bank 2 sensor 1 8--P0401--Exhaust gas recirculation flow insufficient gas detected. Any thoughts before I go Ripping things apart again... Thank You for all your help in this matter. Note how I get the same code 1 & 6. |
OK, I am running some cataclean and top end lube treatment through the system and will keep yas posted.
