2001 Montero Sport 3.5 127,000 mi.
Old Jan 1, 2015 | 06:01 PM
2001Mitch3.5XS's Avatar
Default 2001 Montero Sport 3.5 127,000 mi.
8 codes after the rebuild ????
Hello again, I just got done with the Top and Front rebuild and runs like a champ with a bit of a crappy Idol for some reason. I am getting 8 codes now as follows.
1--P0174-- bank 2 system to lean
2--P0154--oxy circuit no activity detected bank 2 sensor 1
3--P0401--exhaust gas recirculation flow insufficient flow detected
4--Po111-- intake air temperature sensor 1 circuit range / Performance
5--Po107--Manifold absolute pressure circuit or barometric pressure low input
6--P0174--bank 2 system to lean
7--Po154--oxy circuit no activity detected bank 2 sensor 1
8--P0401--Exhaust gas recirculation flow insufficient gas detected.
Any thoughts before I go Ripping things apart again... Thank You for all your help in this matter. Note how I get the same code 1 & 6.
Old Jan 2, 2015 | 05:51 AM
OK, I am running some cataclean and top end lube treatment through the system and will keep yas posted.
Superstar
Sep 22, 2015 10:40 AM
2001Mitch3.5XS
Jul 15, 2014 07:24 PM
egreog1
Jun 26, 2005 10:14 PM
nltankontop
Jul 23, 2004 08:41 PM
