CAI part? Help with the name
Old Nov 30, 2005 | 02:59 PM
TXSpyder's Avatar
Default CAI part? Help with the name
OK I need help replacing the black box thing on the CAI ( has foam thing on it) nobody I know, knows what it is called, the part around the box is cracking.
Old Nov 30, 2005 | 03:46 PM
Default RE: CAI part? Help with the name
Ok the black box is the airfolw meter I think, if that is cracking it will be expensive, if it is just the adapter plate that is cracking then it should be cheap here is a pic of the EVO intake and airflow meter it looks the same on the eclipse except the pipeing goes the other way. the Red is the airflow meter the yellow is the adapter plate and normally the foam thing (i dont have) is called a bypass valve by AEM and it is located either before the adapter plate or after the airflow meter
Old Nov 30, 2005 | 09:18 PM
TXSpyder's Avatar
Hopefully this works but here is a pic the thing between the two metal clamps is cracking?
http://i10.photobucket.com/albums/a1...C/IMG_0320.jpg
Old Nov 30, 2005 | 09:42 PM
Oh ok that is the rubber coupler, if you go to home depot they should have those in the plumbing section in all different sizes. just bring yours in with you... you might want to make sure the 90 degree elbow up near the top of the engine is stil good too
Old Nov 30, 2005 | 10:04 PM
rganders315's Avatar
Those are pretty cheap parts. You got lucky it wasnt something more serious.
Old Nov 30, 2005 | 11:57 PM
TXSpyder's Avatar
Alright I will pass this on to the man of the house, great opportunity to send a man into his favorite store as I hate that store ( unless I am getting flowers) Thanks for the help I will let you know if any new problems are created in this attempt to fix this small one.
Kelly
dmenheere
Aug 6, 2015 06:02 PM
venco2003
Oct 22, 2013 05:28 PM
dksnj
Sep 14, 2006 05:12 PM
burnmyeyes
Aug 16, 2006 01:45 PM
paintballproam
Jun 5, 2006 08:42 PM
