Coolant system problem for 2001 Eclipse
Coolant reservoir keeps draining although there is no indication of leakage. Where did the coolant water go?
What is wrong? Radiator? Any experience or feedback will be truly appreciated.
Thanks
Thanks
If you are not using a 50/50 mix of water and coolant the water will boil off and escape from the drain tube attached to the reservoir. Make sure when you fill it, you dont just use water, mix half with coolant.
john12345
Jan 1, 2010 04:00 PM
