Coolant system problem for 2001 Eclipse
Old Jun 27, 2011 | 11:58 AM
vinh36's Avatar
Default Coolant system problem for 2001 Eclipse
Coolant reservoir keeps draining although there is no indication of leakage. Where did the coolant water go?
What is wrong? Radiator? Any experience or feedback will be truly appreciated.
Thanks
Old Jul 8, 2011 | 09:05 PM
DigitalEclipse's Avatar
If you are not using a 50/50 mix of water and coolant the water will boil off and escape from the drain tube attached to the reservoir. Make sure when you fill it, you dont just use water, mix half with coolant.
vinh36
Aug 20, 2011 01:44 PM
vinh36
Jun 27, 2011 04:32 PM
ruski
Dec 30, 2010 05:32 PM
john12345
Jan 1, 2010 04:00 PM
jrmdir
Aug 19, 2009 12:11 AM
