interior door panel removal - 2000 Galant ES
Old May 15, 2006 | 10:04 AM
fritz's Avatar
Default interior door panel removal - 2000 Galant ES
need to get at driver side window mechanism to expose the window suspension. took the interior panel off but there is another panel integral with the door structure. any one have a diagram to disassemble/reassemble the panel and repair the window suspension? Sounds like everything came loose and the window is dropping into the well. thanks
Old May 19, 2006 | 04:32 AM
Prophet's Avatar
Default RE: interior door panel removal - 2000 Galant ES
There is only one panel to get off. Are you talking about the clear plastic behind the panel? Where you able to take the whole panel off?
Old May 19, 2006 | 10:35 AM
fritz's Avatar
yes, the interior trim panel was removed completely. I didn't realze that the interior door body panel is not removable and that all work is done through the panel cut-outs. Now i have to do the same to the passenger side door to expose the workings of the electric window as a model to work from. Thanks
Old May 19, 2006 | 01:53 PM
Prophet's Avatar
I have the suspicion that you are trying to go thru the cloth piece because that whole panel comes out and if your trying to reach the switches they just snap off the door panel. Here is a picture on how to remove the door panel...
Remove all the screws in blue....
You will get this and can be removed to reach the power window parts....
Some will have a clear plastic like my Galant others have that dark plastic. Hope that helps...
Old May 19, 2006 | 03:02 PM
fritz's Avatar
yes thank you all. I've gotten to where the plastic has been removed. Now I need to figure out the mechanics of the raising and lowering of the window itself. My only thought is to expose the passenger side door as well to observe the mechanical assembly and action. The motor is functionning. It appears the driver side window is off the track and thereofre falls into the well of the door. thanks again
Old Sep 17, 2011 | 02:17 PM
riggerplaner's Avatar
I'm having the same problen. I took the plastic off and can't find how to put the window back on the track. I'm a disabled ironworker and can't afford to go to a garage .Please help,riggerplaner.
Eclipse Novice
Jan 6, 2008 06:29 PM
rocky2024
Oct 21, 2006 04:17 PM
eclipse_hntr
Aug 14, 2006 10:58 PM
cybergheist
May 23, 2006 01:29 AM
nachos
Sep 13, 2005 07:20 PM
