L200 Vibration
Old Dec 18, 2014 | 09:26 AM
wm10001's Avatar
Default L200 Vibration
Good afternoon, I have a 06 Reg L200 4life. When I travel over 40-45 mph there is a vibration from underneath the vehicle. Below this speed the vehicle runs smooth. I have replaced the Transfer Gearbox Mounting as this was defective. I think it helped a bit by doing this but the problem is still there. Sometimes the vibration can be brought on by going over a bump in the road. After slowing down the vehicle the vibration disappears. The vibration sounds like the vehicle is travelling over a rough bit of road. Can anyone help? The propshaft uj's seem to be ok. How much play should be in the center bearing?
Old Dec 18, 2014 | 11:55 AM
Akzle's Avatar
there should be no play in bearings.
Check oil levels, boxes, diffs, Wheel bearings, shaft hangers, engine mounts.
Id be thinking rear diff/crown wheel.
Old Dec 18, 2014 | 01:15 PM
wm10001's Avatar
Ok, thanks for that. Will check all of the above.
Old Dec 18, 2014 | 07:39 PM
up-and-down's Avatar
Also the drive shaft make sure it isn't loose or out of balance.
L200man
Other Mitsubishi Models
Apr 12, 2006 06:00 PM
C2LLN
Apr 9, 2006 08:17 PM
vormannen
Jun 8, 2005 05:54 PM
l200luke
Jul 4, 2004 01:11 PM
bull72
Feb 12, 2004 11:18 PM
