Lifted up? Or down low?
Old Dec 19, 2006 | 11:39 PM
  #21
cchrisj01's Avatar
Default RE: Lifted up? Or down low?
why was it broken all the time? was it because of the turbo setup?
Old Dec 20, 2006 | 10:22 AM
  #22
ORIGINAL: cchrisj01
no just because the car was cursed. Betweenthe timing belt going and replacing the head, and then throwing a rod and replacing the motor.
Old Dec 20, 2006 | 04:17 PM
  #23
ORIGINAL: TheEngineer
ORIGINAL: cchrisj01
thanks for speaking for me
Old Dec 20, 2006 | 08:05 PM
  #24
cchrisj01's Avatar
well was that because of the turbo??
Old Dec 20, 2006 | 11:40 PM
  #25
ORIGINAL: cchrisj01
no all the problems were prior to the turbo. I was getting ready to turbo it then the motor tossed a rod threw the oil pan and block. then I get a new motor which a month later the timing belt which was brand new shreaded and I needed now to rebuild the head cause the valves hit, then my intake manifold cracked and the throttle body broke off I had to replace the entire manifold without relizing the reason for that was my Ebay intake. then the new manifold same thing a month later so I had mitsu fix it and I sold the car. The new owner got all the turbo parts with the car but he had the manifold break on him 3 more times before I convinced him it was the intake
Old Dec 20, 2006 | 11:56 PM
  #26
cchrisj01's Avatar
Crazy, well I was talking with some people and they said its nota good idea to turbo a non turbo because it throws off the compression and takes the engine life away by 40%. true?? I need my eclipse to last at least 3 more years until i graduate. do you think if everything was fine on your GS, would it have lasted with the turbo kit? Because they said that it will maybe last 25,000 miles lol
Old Dec 21, 2006 | 12:01 AM
  #27
ok for the record my Eclipse was not broken in properly by the first owner.
The 3G GS\RS can be turboed with 0 problems TRUST ME I KNOW. there are guys who are making a little over 300HP on the stock motor with turbo kits made by Russ Sanderlin (Tearstone) I have seen them in person and some have had there carsr turboed for about 3 years now with no motor trouble.
If you get the car tuned properly you wont have any worries at all if you stay under 14 PSI youll be fine too. I would stay at 10PSI but the car can handle 15 but why push it. 10 PSI will make around 280WHP that will be plenty fast and with a good tune plenty reliable
Old Dec 21, 2006 | 01:16 AM
  #28
cchrisj01's Avatar
Yeah see thats what I am saying. Exactly what I am saying. Tuned at 280 horse can beat stock Trans AM WS6's. So I was planning on getting my kit from www.turbokits.com.
Think that is good?
Old Dec 21, 2006 | 09:04 AM
  #29
That kit will not get you as much HP. Tearstones kit was better but you cant buy his anymore I dont think. You cant tune that car with an SAFC you will need at the least a Greddy Emanage
Old Dec 21, 2006 | 01:32 PM
  #30
cchrisj01's Avatar
You mean I will need the Emanage if I get the kit from turbokits.com?
