Mirage Window regulator!!!!!!!
Hi I'm driving a 1998 Mitsubishi Mirage asti 2 door coupe. Can Any one tell me if the electric window regulator is the same as any other mitz.
Or If any one knows the exact lenght of the cables used in the regulator, because the motor is fine and I could get cables made if I knew the exact lenght of them.
Thanks in advance
Thanks in advance
RE: Mirage Window regulator!!!!!!!
According to my local Mitsu dealers parts site, the same switch is used from 97 to 02.
I start at http://donherringmitsubishi.com and go to parts/order parts. It will walk you through finding what you need if the link below doesn't work for you.
http://www.trademotion.com/partlocat...98&catalogid=1
Good luck,
~Steve
Good luck,
~Steve
