Power window regulator
Old Aug 22, 2006 | 08:29 PM
ajav05's Avatar
Default Power window regulator
I have a 1997 Montero SR and I need the right front window regulator I am trying to avoid the dealer price, so my question is , does any other model or year fit the 1997 SR without any problem?
Old Aug 22, 2006 | 08:40 PM
Default RE: Power window regulator
i did alittle searching around here online at junkyard and it came up with some 2000 & 2001 montero's and montero sports. for around 50-100.
Old Aug 22, 2006 | 08:51 PM
ajav05's Avatar
I guess that the 1997, 2000 and 2001 montero use the same regulator?
Old Aug 22, 2006 | 09:29 PM
idk maybe its 97-2001. Im just telling ya what i found. But id definetly just look into a junk yard cuz like i said i found one for $50
Old Aug 22, 2006 | 09:30 PM
off roader's Avatar
try car-part.com or msrecycling.com or last but not least your local pick and pull salvage yard. Any gen II montero's setup should work (not sure if it has to also be a power setup or not).
Old Aug 22, 2006 | 11:29 PM
Manybrews's Avatar
its doubtful the 01 would fit, as its a totally new body style.
Old Aug 22, 2006 | 11:54 PM
ajav05's Avatar
Thanks Everyone for your replies.
Old Aug 23, 2006 | 09:56 AM
ORIGINAL: Manybrews
well it must because if i do a part search for this specific part for a 1997 it came up with parts from a 2000 and a 2001 that would work. Its not really a complicated part so i dont think its to wierd that they would use the same one for all the years.
Old Aug 23, 2006 | 08:21 PM
Manybrews's Avatar
the door is a totally new door design.
Although its possible, I very, very much doubt its the same. why not call your local dealership? then you'll get the answer for sure.
McNeil
May 28, 2009 09:05 PM
ajan246
Sep 21, 2007 04:56 PM
import tuner
Jul 24, 2007 11:33 PM
tjbiker031
Apr 4, 2007 11:52 PM
gersrt
Jan 16, 2006 07:23 PM
