Mitsubishi Colt 2003 EPS Probelms
Hi there,
I have a 2003 Mitsubishi Colt. (4wd) Have just recently had problems with the EPS steering. I would start the car and the eps light would stay on. shake the steering and it would go off. Ok to drive and had assit. Turn car of and start again some situation. And now it sometimes goes of when you shake the steering other wise it just stays on. Fault codes are: C1531 MOTOR TERMINAL VOLTAGE C1541 FAIL SAFE RELAY STUCK ON C1607 ECU FAILURE. C1541 FAIL SAFE RELAY STUCK ON - CLEARED! C1607 ECU FAILURE - CLEARED! C1531 MOTOR TERMINAL VOLTAGE - Stays in system Any help would be so great! :) Car looks like this http://media.autobase.co.nz/VehicleI.../1412298_5.jpg |
Hi, also have a colt 2005 that I am experiencing the same fault with. C1541. did you find a fix for this problem?
Plz keep us posted to find out how you make out here 2003
