MMCS NR 242 install help adding USB port
Needed to install a camera, I purchased the one **** non Navi and to my luck it shared the same pinouts and also the usb port was on both. Got the usb in glovebox, that helped. Now looking at pin out diagram site I can confirm it.
The next swap comes from the one **** radio starting the screen to not respond to touch, read here it’s common to fail.
Got a good deal on eBay, went for it.
Spoiler
Radio is up and running without the car bus present and no Bluetooth either. GPS is working just need to purchase the antenna.
Excellent music quality with the SD Card, not user friendly, specially if your music inventory is huge.
I would like to know if I can hardwire the usb 4 or 5 wires connection directly to radio, because I would love the usb port back. The usb port D122 has 5 inputs
I can activate also AUX also in hidden menu, that could be another option to hardwire directly.
For me to add the Bluetooth unit which car doesn’t have 18 pin connection without knowing pin out is impossible.
Radio, camera, gps all work. What options do I have. A FM transmitter through radio station solution is not for me.
How to add D122 spliced to 18 pin connection. Can’t seem to find the 18 pin female plug either online. Here’s the USB cable.
Last information found regarding the pins and video signal
The video signal(54) I believe is to be connected to a GND Chassis.
If this worked on older MMCS, specifically before 2014 when the wiring changed, should be no problem.
