my idleing problem
Old Apr 28, 2008 | 05:21 PM
BLAZE GS's Avatar
Default my idleing problem
there the link to the video hope you guys can helpthe idle like that only on a cold start.......
http://www.youtube.com/watch?v=CRzIjlP0kGA
Old Apr 28, 2008 | 06:53 PM
dsm1990gsx's Avatar
Default RE: my idleing problem
Check your cam timing, if thats off you'll getsurgeing idle like that. My gsx did that after doing a lot of engine work to it. If you dont have a timing light try playing w/ the cam position sensor a little and keep an eye on where the idle is.
Old Apr 28, 2008 | 07:04 PM
BLAZE GS's Avatar
i just adjusted it with a timing light the night before the video so i dont know what is causing it
Old Apr 28, 2008 | 07:12 PM
dsm1990gsx's Avatar
Ok dissconnect the isc motor/position sensorconnector, its a single wire. If it stops when its disconnected try adjusting it either backing it off or in and reconnecting it and see if it continues.
Old Apr 28, 2008 | 07:44 PM
IAC motor...
Old Apr 28, 2008 | 08:13 PM
dsm1990gsx's Avatar
ORIGINAL: Sebba
IAC motor...
My 90 did the exact same thing when I first started up and just playing around the cam position sensor and adjusting the idle speed position sensor and I got mine to idle perfecty at 750 rpms.
Old Apr 28, 2008 | 10:31 PM
BLAZE GS's Avatar
i also have the b/s elim on my botor so it runs rougher idk if that counts for anything
Old Apr 28, 2008 | 10:45 PM
BLAZE GS's Avatar
ORIGINAL: dsm1990gsx
where is it located?
Old Apr 29, 2008 | 06:42 AM
dsm1990gsx's Avatar
I have the b/s eliinated too and that wont make a difference.
Its located on the top on the t/b I can get a pics for you when I get home from work, its a single wire connector.
Old Apr 29, 2008 | 06:21 PM
BLAZE GS's Avatar
pics would help alot
