one thing after another
ok I just got all of my new stuff into my car. I replaced the trans, clutch, both front axles, and put a header on my car. So I was pumped I finally got to start it for the first time then as I start it the water pump goes out! Do I have to pull the engine to replace this? Ok then to make matters worse I went to pull it out of my garage and I have all but reverse! I don’t know what to do im a little pissed off and im running out of cash! Can you guys give me some advice? Thanx for anything..
RE: one thing after another
Well if you have all but reverse I would say you have a trans problem. Warranty? The water pump you should be able to do in the car. I believe that the water pump is timing belt driven on these isn't it? I can't remember. Water pump isn't a big deal though.
yeah i think oyur right about the water pump well see the trans really didnt want to go into first but it finnaly did. do you think since its new i just need to work the gear lube into it?
