one thing after another
Old Jan 9, 2007 | 12:10 AM
GSXPimp's Avatar
Default one thing after another
ok I just got all of my new stuff into my car. I replaced the trans, clutch, both front axles, and put a header on my car. So I was pumped I finally got to start it for the first time then as I start it the water pump goes out! Do I have to pull the engine to replace this? Ok then to make matters worse I went to pull it out of my garage and I have all but reverse! I don’t know what to do im a little pissed off and im running out of cash! Can you guys give me some advice? Thanx for anything..
Old Jan 9, 2007 | 09:22 PM
Sanguinius's Avatar
Default RE: one thing after another
Well if you have all but reverse I would say you have a trans problem. Warranty? The water pump you should be able to do in the car. I believe that the water pump is timing belt driven on these isn't it? I can't remember. Water pump isn't a big deal though.
Old Jan 10, 2007 | 12:01 AM
GSXPimp's Avatar
yeah i think oyur right about the water pump well see the trans really didnt want to go into first but it finnaly did. do you think since its new i just need to work the gear lube into it?
LOWnEASY
Jan 18, 2014 12:56 AM
TheEngineer
Feb 21, 2008 02:10 PM
AntDcruze
Jul 3, 2007 09:53 AM
Sanguinius
Nov 22, 2006 04:15 PM
