Radiator leak
Old Jun 24, 2007 | 01:38 PM
adro1982's Avatar
Default Radiator leak
Is it possible for radiator fluid to be leaking inside the passenger side of the car- maybe even thru the A/C?? I can't see any fluid on the ground under the car. There is definitely fluid on the floor board of the front passenger side of the car.
Old Jun 24, 2007 | 04:02 PM
I Drive Naked's Avatar
Default RE: Radiator leak
Yes, coolant can leak inside the car.
Your heater core is leaking and needs to be replaced.
When you turn on the heat, you should see the glass start to fog up.
Heater cores require the dash to be pulled out.
Never a fun job.
Dan Dossey
Apr 4, 2015 09:53 PM
TheRock0720
Nov 12, 2010 12:30 PM
T76 turbo
May 7, 2004 08:49 AM
Duck
Apr 2, 2004 03:13 PM
smitty225
Mar 24, 2004 03:38 AM
