View Poll Results: A poll
Beautiful!
27.78%
Great
50.00%
Average
13.89%
Below Average
2.78%
Horrid!
5.56%
Voters: 36. You may not vote on this poll
Rate My Car Please
Old Oct 8, 2006 | 11:26 PM
bdhunter's Avatar
Default RE: Rate My Car Please
Honestly, I'm not a big fan of the wing either :-p but hell, it was expensive!
anywho, so you know... specs of the car are:
Engine Specs:
- 2.0L 4cyl DOHC 16V EFI Turbo
- 1998 420A Engine bored and honed .020" over
- Crower Billet Connecting Rods, Bushed for .827" floating pin
- JE Forged Pistons with pins and locks, 8.5:1 (.020" over)
- JE Forged Piston Ring Set
- MLS Headgasket
- Hahn RaceCraft Super 20G Turbocharger
- Synapse Engineering Missing Link
- Fluidyne Radiator
- RRE Catch Can
- APEX'i Power Intake
- APEX'i Front Mount Intercooler
- Mandrel Bent and Powdercoated Intercooler Piping
- Powdercoated: Valve Cover, Intake Manifold, Turbo Housing, Blow Off Valve, Strut Tower Bar
Mounts, Thermostat Housing, Radiator Mounting Brackets, Heater Hose Hard Lines, etc.
- Thermal-flex Reinforced Silicone Intercooler Connectors
- Ported, Polished, and Gasket Matched Intake Manifold
- Turbo-Xs Type H Blow Off Valve
- Hahn RaceCraft Exhaust Manifold for the Super 20G Turbocharger (ceramic coated)
- Custom Mandrel Bent 3' Down-pipe by Tachyon Performance
- Custom 3' Mandrel Bent Exhaust by Tachyon Performance
- Magnaflow Performance Race Series Muffler
- Dynomax Race Magnum Bullet Muffler [In-line]
- Unorthodox Racing 30% Underdrive Crank Pulley
- Unorthodox Racing Adjustable Cam Gears
- Clutchmasters Stage 4 Ceramic Modular Clutch
- Stillen Short Throw Shifter
- Vitek Spark Plug Wires
- NGK Spark Plugs (BKR7E)
- MSD DIS-2 Ignition System
- EverStart Maxx 1000 Battery
- Hahn RaceCraft 'PortFueler' Fuel System
- Bosch 1:1 Fuel Pressure Regulator
- Stainless Steel Braided Fuel Lines
- Accel High Performance Fuel Injectors
- In-line Fuel Pump from Hahn RaceCraft
- Greddy Profec-B Electronic Boost Controller
- Greddy Turbo Timer
- Stainless Steel Braided Oil line
Suspension Specs:
- 18" x 8" Enkei Wun-Gun Rims
- Yokohama Parada Spec-2 235/40/z18 Tires
- Tokiko Illumina 5 Way Adjustable Shocks & Struts
- Eibach Pro-Kit Sport Springs
- Stillen Camber Kits
- Stillen Front Strut Tower Brace
- Stillen Rear Strut Tower Brace
- Stillen Cross drilled and Slotted Rotors (Front)
- Stillen AP Racing 4 Piston Calipers (Front)
- Stillen High Performance Brake Pads (Front)
- Stillen Stainless Steel Braided Brake Lines (Front)
- Stillen Cross Drilled Rotors (Rear)
- Stillen Stainless Steel Braided Brake Lines (Rear)
- Metal Matrix Brake Pads (Rear)
Body Specs:
- Stillen Front Fascia
- Stillen Commando Wing
- Carbon Fiber Hood (paint matched to body color)
- Dynamat Hoodliner
- Clear Front Side Markers
- AngelEye Chrome Projector Headlamps
- Original Tail Lights
- Tinted Windows
- External Antenna removed and internal put in
Stereo Specs:
- Alpine CDA-7840 Head Unit w/ AI-Shuttle Control
- Alpine ERA-G320 Digital Sound Field Processor
- Kicker Resolution Titanium Dome Tweeters (Pillar-Mount)
- Kicker 6½' Resolution Midbass (Front Doors)
- Kicker Resolution Crossovers (Front)
- Kicker 1' Titanium Dome Tweeters (Rear)
- Kicker 6½' Mid-bass (Rear)
- Kicker Resolution Crossovers (Rear)
- Kicker ZR240 Amplifier (Fronts)
- Kicker ZR240 Amplifier (Rears)
- Kicker ZR240 Amplifier (Sub)
- Kicker 12' Competition 25th Anniversary Ed. (Cast in Chrome)
- Custom Fiberglass Trunk, Sub is Inverted, Custom Amp & Wiring Racks (Built by Kicker rep)
- Platinum F3 Wiring, RCA's, Distribution Blocks, Fuse Holders, 1/0ga Power & Ground, etc.
Interior Specs:
- Complete Custom Interior
- Black Carpet
- Black with Red Accented Custom Floormats
- Black Painted Trim
- Black Headliner
- Stitched and Embroidered Vinyl Seats Front and Rear, Black and Red
- Black and Red Door Skins
- Matching Black and Red Shifter and Shift Boot
- Autometer Ultra-Lite Series Gages (Red backlight matched to stock)
- Boost Pressure (Pillar Mounted)
- Air/Fuel Ratio (Pillar Mounted)
- Exhaust Gas Temperature (Gage Cluster Mounted)
- Oil Pressure (Gage Cluster Mounted)
Old Oct 9, 2006 | 01:06 AM
ORIGINAL: bdhunter
that is the stupidest thing I have herd all day. who buys a wing just because its expensive. even worse that its an ugly wing IMO
Old Oct 9, 2006 | 01:30 AM
davidmitsusrock's Avatar
flame me as much as you want but i like the wing....
Old Oct 9, 2006 | 04:58 AM
After all that what is your hp to the ground?
Old Oct 9, 2006 | 11:31 AM
bdhunter's Avatar
Hahn's Racecraft has a similar setup in one of their cars, and they estimated between 450-500 hp with a proper tune-up and racing blends, however, i have not had it tested anywhere so I'm just going by what they told me
Old Oct 9, 2006 | 04:21 PM
99madewell's Avatar
I like the car, good combination of engine and body mods. looks good!
Old Oct 9, 2006 | 04:23 PM
Well i say get a dyno... although i do agree with ^^
Old Oct 9, 2006 | 07:07 PM
98eclpsrider's Avatar
now that i look at it more, your bumber looks like a hybrid of mine that i have on my car, it looks more organic.
Old Oct 9, 2006 | 09:01 PM
Sanguinius's Avatar
ORIGINAL: bdhunter
Engine Specs:
- MLS Headgasket
- Fluidyne Radiator
- RRE Catch Can
Suspension Specs:
Body Specs:
- Dynamat Hoodliner
- Tinted Windows
Stereo Specs:
Interior Specs:
- Black Carpet
- Black Headliner
All right all these mods... NMow my question is who did the work? SOMEONE had to put in the wrenchtime. What shop did it?
Old Oct 9, 2006 | 09:21 PM
^^ I was thinking the same thing I am under the impression the car might have been bought with the mods based on how he posts pics every where to show it off (nothing against him if he did do the work cause that is what I hope hehe)
