Source of Oil Leak
Old Aug 2, 2006 | 07:38 PM
andre2000's Avatar
Default Source of Oil Leak
Hello all,
I posted before about my speedo problem and I got tremendous support from
everyone. So now I wanted help determining the source of the oil leak that developed
in this last month.
Bkgrnd info: '99 Automatic 2.0L DOHC Eclipse.
there is oil leaking all over the underbelly of the car...spewing on the catalyc converter and making it smoke. I changed the oil a month ago and my Father-In-Law commented how clean it was under there. Not anymore. Also, the check Engine light comes on (wow cant imagine why) and the coolant seems to be dissapearing somewhere (not on the driveway ever).
I was told by some other poster in another thread that it is natorious for these engines to blow a head gasket, particularly in the driver's side towards the firewall. The location of the leak certainly does suggest this, but I'd thought I'd get a discussion going as to other possible causes considering all the facts. I dont want to go into this blindly. So here are some pics
Basically there is oil everywhere, including above the headgasket area. Note that there is no sign of coolant inside the cylinders, no milky fluid on the dipstick. Also I checked the spark plugs and there is no sign of oil inside the cylinders. Look at the pick to see what I'm talking about.
Edit...Ugh Photobucket sucks. they keep shrinking my images
Old Aug 2, 2006 | 07:46 PM
Default RE: Source of Oil Leak
head gasket.
PS.. your plugs are ****ed lol
Old Aug 2, 2006 | 07:48 PM
Manybrews's Avatar
as I said, they ALL suffer from external leaks from the head gasket (located on the rear drivers side corner of the engine, as its the oil feed to the head).
other potential leaks are from the valve cover (although its usually just a little vapor).
a few other leaks that occur are usually HUGE leaks when 1) the oil pressure sensor ruptures, or 2)one of the cam seal pushes itself out of the head.
neither of the latter are common, but I have seen them each at least 2-3 times. Both of the latter will leak POOLS of oil onto the ground in short order only when the engine is running.
internal head gasket leaks are non-existant UNLESS someone severely overheated the engine, in which case the head would probably be warped. So you're probably not consuming coolant. rather, the water pumps have a tendency to "dribble" over time. Not so much as to be considered failed, but a little leak nontheless.
the headgaskets were redesigned twice in the life of the engine.
often, on older cars that arent worth much, the oil leak can be eliminated or limited mearly by removing the valve cover and re-torquing the head bolts, which loosen considerably over time.
it may not totally eliminate it (it usually does), but usually slows it to a drop or two a week. generally its worth trying.
of course, you could kill two birds with one stone and do the head gasket, which requires removal of the timing belt anyway. then the water pump access is easy.
Old Aug 3, 2006 | 11:54 AM
andre2000's Avatar
Thank you!
I dont know what happened to your other post in the other thread but oh well.
I was hoping this would attract you to another posting.
Your advice is excellent dude. Thank you.
More questions, because I want to get this right.
The pictures have been shrunk by photobucket so you cant read it anymore.
In the first one it shows an arrow pointing to the valve cover seam. Sludge is
built up between the valve cover and head. Also, it does look like something is
leaking out of the cam sensor aswell. It doesnt seem like those two things are what is
soaking the underside of the car with oil.
Observations:
I did notice more signs of leakage after I get off the highway after an hour or so going around
75-80mph the whole way.
We did notice that the valve cover bolts were very very loose, not even finger tight.
What I gathered:
So the best route I take it would be to first remove the valve cover, put it back and retorquing the bolts.
If that doesnt work then I should prepare to replace the head gasket, and water pump while I'm down there.
This would be a good time to replace the timing belt too huh?
Any suggestions for a particular brand of headgaskets? I'm staying away from ebay ones...
What about timing belts? Any good aftermarket ones?
BTW, how do you know so much?
Old Aug 3, 2006 | 11:58 AM
You can get a good headgasket any place really.
As for hte leaks surrounding the valve cover this is simply down to the loose bolts. Simply tighten them and that will be it really. That problem is totally seperate from the head gasket problem and it will not stop the leaky headgasket. Also, yes this would be a good time to do your general maintanance like timing belt, water pump. Not to mention your plugs! lol
Old Aug 3, 2006 | 02:43 PM
Manybrews's Avatar
ORIGINAL: andre2000
a bit of vapor seeping from the valve cover and cam seal is fairly normal over the years. Its usually not enough to be considered a "leak", and theres not much you can do about it.
you could replace the gaskets, which may help. Note that you CANNOT REUSE the valve cover gasket once it has contacted oil. It is designed to swell with contact of oil to improve the seal, but once it swells you will never get it back to its original shape, so if you plan on retightening the head bolts be sure to get a new gasket and 4 new plug seals.
Observations:
normal for the head gasket leak. It also has a tendency to blow around in the wind, so dribbles of oil will splatter at speed.
the bolts have shoulders on them.. you cant really overtighten them, so just snug them down.
What I gathered:
yes, that would be the way I would go. clean the engine after your done so you can monitor how much (if any) oil continues to leak.
yes, REPLACE THE TIMING BELT! no matter what you do with the oil/coolant leaks, the belt is good for 100k only, and the engine is an interference engine meaning you will bend valves severly if the belt breaks why you're driving.
I would recommend ONLY the factory gaskets, as they are now completely redesigned and work fantastic. They are (like most automakers) now made of multi-layered steel shims.
and I know so much because Ive been a mitsu tech for 15 years.
Old Aug 3, 2006 | 03:44 PM
andre2000's Avatar
Do you know the part # for the head gasket and valve gaskets etc... so I can order online?
Old Aug 3, 2006 | 03:50 PM
Manybrews's Avatar
ORIGINAL: andre2000
actually, I have a TSB with a bunch of information you may want.
gimme an email address and Ill shoot it to you.
Old Aug 3, 2006 | 04:01 PM
andre2000's Avatar
andre@aiscience.net
cc to paquitin2000@yahoo.com
Damn, I cant thank you more for the help!
Old Aug 3, 2006 | 04:03 PM
Dude you are an asset to the forum.
Also... everyone with problems take note of this guy. Every problem should be presented to us this same way. Pictorial diagrams!
