Water leaking cause I can't find the drain tube to unblock
Old Jul 11, 2006 | 09:59 PM
owensth's Avatar
Default Water leaking cause I can't find the drain tube to unblock
I have a 2004 Endeavor, The air is leaking into the front passenger foot area. I had it up on a lift and can not find the drainage tube to unclog. Where is the darn thing located?
Old Jul 11, 2006 | 11:00 PM
dirtwagon's Avatar
Default RE: Water leaking cause I can't find the drain tube to unblock
Did your warranty expire already? I would go to the dealer, your truck was probably manufactured in late 2003, so you should still be covered unless you have run over the alloted mileage.
Old Jul 25, 2006 | 12:36 AM
Manybrews's Avatar
the drain tube is NOT accesable from outside the car. it requires major disassembly of the interior and HVAC system to access.
Old Aug 10, 2010 | 02:43 PM
gregsguitars's Avatar
Pain in the ****, Mitsubishi knows about the blockage in the AC drain tube but will not do anything to fix it.
ydna888
4th Generation
Nov 2, 2010 10:21 PM
bdcorey723
Jul 16, 2007 05:23 PM
tidus10
Mar 7, 2006 10:51 PM
hellsheep
Aug 7, 2005 06:34 PM
monkey714
Aug 3, 2004 11:31 PM
