Intake, Headers and Exhaust Custom Exhaust? New Headers? Need Opinions on Intakes? Discuss making your ride breathe better here.
endeaver exhaust
Old Oct 3, 2006 | 11:06 AM
vinson's Avatar
Default endeaver exhaust
new here first post but need to know why i cant remove the cat con and resenator off my 06 endeaver and let it breath a little better i would leave the stock muffler just remove some back pressure i dont see any sensors down from the head pipe has anyone tried this yet????? thanks all
Old Oct 12, 2006 | 12:25 AM
vinson's Avatar
Default RE: endeaver exhaust
no body
Old Oct 12, 2006 | 10:01 AM
well there should be 02 sensors on the piping also, im not familiar with te endeavor, but it would seem to me that it would have them. Aslo if you do that i dont think you will pass emmisions either
Old Nov 20, 2006 | 07:44 PM
RMUDBUGS's Avatar
Your check engine light would come on.
Old Nov 21, 2006 | 01:32 PM
shreff99's Avatar
why not get a custom exhaust system??
Old Nov 21, 2006 | 09:11 PM
vinson's Avatar
2 reasons 1 being with no cat or resenator that is a custom exhaust just because you did not spend hundreds of dollars does not mean that removing back pressure will not improve performance or mileage #2 any mods that can be done for free and keep a ride dependable and drivable have got to be the way to go
Old Nov 22, 2006 | 10:26 PM
vinson's Avatar
rmudbugs why would engine light come on o2 sensor is up in front of cat in y pipe not in cat like some vehicles or am i missing something else
Old Jan 5, 2007 | 12:25 AM
snesar's Avatar
Yes, I've done it and it works. There is no O2 sensor after the 2nd CAT so it can be removed without any CEL or any other problems. I have a flagged straight pipe and flanged stock CAT so that I can switch them in minutes, if needed (inspection or dealer visit).
However, there is one thing I have different than what you asked. I did not remove the resonator. If you want to do this for flow (not sound), you dont need to remove resonator as it is a straight thru pipe with perforated wall (inside). So if anything, it helps to reduce the sound harsness.
I left the stock muffler with an after market steel tip. I can definately notice the motor reving freely now.
Its encouraging to see someone else trying to modify their Endeavor. Please keep your thoughts and experiements comming, forum or PM.
Thanks
Ktsheroes
Jan 21, 2011 06:49 PM
Djabelnyc
Jan 19, 2011 05:22 PM
q7suited
Aug 12, 2008 05:48 PM
anko_kun
Mar 6, 2008 08:54 AM
vinson
Jul 27, 2007 09:58 PM
