Flex Pipe Needed!
I took my car to the shop and they found out that I need a new flex pipe. They said its only gonna be found from a manufacturer but I really dont know how to get my hands on one. Any suggestions?
then they are a dumb shop to think you need a manufacturer. If you go to almost any muffler shop they will have standard flex pipes in stock and all they will do is cut the old one out and weld the new one in. Shouldnt cost much. I think i got it done for like $30
no its not a protective covering. The pipe is exactly what it sounds like with the name "flex" pipe. It is there because the motor torques a bit when you rev it or are driving, and in order to prevent cracking in the exaust system piping or flanges they install a flex pipe on the downpipe in order to allow it to flex with the motor and take the movement out of the exhaust. I know exactly what part you are talking. And it is not uncommon at all for them to fray and break since it is a brittle flex metal material. That is why i dont understand the complication with them. Because any universal flex pipe will do the trick as long as its the correct pipe size
