Intake, Headers and Exhaust Custom Exhaust? New Headers? Need Opinions on Intakes? Discuss making your ride breathe better here.
HELP FAST CAR WONT START AFTER INSTALL!!!
Old Nov 14, 2006 | 09:16 PM
mountaindewguy's Avatar
Default HELP FAST CAR WONT START AFTER INSTALL!!!
i go to work in 4 hours!!! i installed the injen short ram, now the car wont start! 01 v6 eclipse.
i forgot to unplug the MAS before i installed it (i did disconnect the battery cable) so after words i disconnected the battery and the sensor, reconnected the battery and put the plug back in and still no start. so i completely disconnected the battery and the MAS. could it be that i have to plug in the MAS before reconnecting the battery? HELP FAST!
Old Nov 14, 2006 | 09:20 PM
silvercoupe97's Avatar
Default RE: HELP FAST CAR WONT START AFTER INSTALL!!!
Did you plug the MAF back in? Or MAS, whatever you have that's connected to the intake.
Ooops, read too fast, lol.
Old Nov 14, 2006 | 09:22 PM
Try disconnecting the battery and press then press the brakes and hold it for about 15 seconds. Plug the power back up and try to start it again.
Old Nov 14, 2006 | 09:25 PM
Sanguinius's Avatar
Yeah when you disconnect the battery you have to kill residual juice in the circuits. That's why it takes at LEAST 15 minutes if you're not messing with stuff for it to register to reset.
Old Nov 14, 2006 | 11:00 PM
nothing, still wont start. it turns over, but it doesn't actually start.
Old Nov 14, 2006 | 11:07 PM
Did you put all the vacuum lines back the way they were? Check your fuses and fusible links in the engine bay fusebox.
Old Nov 14, 2006 | 11:12 PM
everything is fine, and the only vacuum line i touched was the one connecting to the intake piping.
damn i'm lost.
Old Nov 14, 2006 | 11:18 PM
Have you tried to reinstall the stock airbox? I doubt that it'll do anything but it won't hurt to try.
Old Nov 14, 2006 | 11:25 PM
i'll have to wait till tomorrow for that, any other ideas>?
Old Nov 15, 2006 | 12:26 AM
ok i tried starting it, and when it chugged slightly i nailed the gas and held it, but the only thing tht happened is smoke came out the exhaust some, and the INSTANT i let go of the gas it died....?????
