Intake, Headers and Exhaust Custom Exhaust? New Headers? Need Opinions on Intakes? Discuss making your ride breathe better here.
sheet metal intake...
Old Dec 8, 2007 | 08:57 AM
_Adrian_'s Avatar
Default sheet metal intake...
hey guys ...
im at it again..
was looking at the magnus intake, but im a bit confused...
whats differencebetween the 1G and 2G heads ???
and will the 1G intake fit in the engine bay of the 2G ???
i know of the port difference and cam sensor, but am i over-looking something ??
i have found a 1G head and its being shipped on monday, also i want to get the intake and TB taken care off.
its gonna get the full treatment.
gonna deck it, polish and port match, oversize the valves, DKS cams, Dual Spring setup, new lifters and rockers, 700cc injectors.
going to be using the 1G TB for now, untill i break down and get the accufab unit.
Old Dec 25, 2007 | 04:07 PM
oh_what_up's Avatar
Default RE: sheet metal intake...
the magnus intake manifold is amazing. Throttle response, horsepower, blah, blah, blah. But there is a big difference between the 1g and 2g. The 1g head (the one being shipped to you) has larger runners and a has a bigger inlet port. The throttle body is also bigger, but since you'll use the 1g TB you'll be alright. However, there is a little bit of prep work in making the 1g head fit on the 2g block. The head bolt holes need to be enlarged to fit onto the 2g block, etc. Do some research on it. Good luck to you brother if you need anything else, let me know.
Old Dec 25, 2007 | 06:15 PM
_Adrian_'s Avatar
actually was gonna use a cometic headgasket and ARP head studs
Skiddy
May 8, 2016 11:53 PM
osarmentof
Nov 2, 2007 07:57 AM
tcp
Jun 20, 2007 07:46 PM
Sebba
Nov 1, 2006 11:50 AM
mturker
Nov 23, 2004 11:59 AM
