Intake, Headers and Exhaust Custom Exhaust? New Headers? Need Opinions on Intakes? Discuss making your ride breathe better here.
Thinking of selling.
Old Feb 10, 2008 | 09:30 PM
  #21
chopper1's Avatar
Default RE: Thinking of selling.
Do you have an air/fuel ratio meter. Mine was reading lean and spitting black stuff out the tail pipe. The O2 sensor on the header was bad and the computer was richening the mixure. Gas mileage was around 17. 28mpg now. Just a thought.
Old Feb 10, 2008 | 10:30 PM
  #22
newguy2007's Avatar
i went to auto zone and had my check engine light tested and they said it was an o2 sensor. Do you think this could be it? Also someone told me to reset my ecu. would that work?
Old Feb 12, 2008 | 04:15 PM
  #23
newguy2007's Avatar
anybody have an idea
Old Feb 12, 2008 | 05:01 PM
  #24
dsm1990gsx's Avatar
ORIGINAL: newguy2007
i finally did a compression test on my car. The psi is supposed to be like 178 and mine is 150. I changed the plugs and ran it pretty hard and found a small miss in my turbo. So now i have new plugs, low compression, still a lot of smoke and a small miss in the turbo.
Any ideas on what it could be?
Like what emonz57 what were the compression readings on the other 3 cylinders? Also did you do a wet compression test to eliminate if its a ring problem. And what is a "miss" on the turbo?
Gstfat
Sep 2, 2007 10:33 PM
Laxstar785
May 19, 2005 08:33 PM
Ace2133
Sep 24, 2004 11:32 AM
Chupper
Feb 22, 2004 07:11 PM
Mak3
Jan 15, 2004 12:21 PM
